It is currently Mon Aug 04, 2025 8:27 pm
PostPosted: Mon Feb 09, 2009 11:28 pm
There seems to be two schools of thought on this. Those who build in the same enviroment the guitar will live in; if the average RH is 47% then they build in 47% RH. The other school of thought is you should build lower than what the average RH is where the guitar will live because the guitar can take an increase in humidity better than it can a decrease.
So the question is which method do you use and why? What I'm really wanting to know is are there any downsides to building with the RH lower than where the guitar will live? For those who do build with a lower RH how much lower do you go?
Jeremy Douglas
PostPosted: Mon Feb 09, 2009 11:38 pm
Well, I'll start in on this. I certainly don't have the answer but I do have my own opinion and decision.
I live in an area that can see humidity changes from 20%-90% over a 12 month period. Now, that's an outside measurement. Inside, It's more like 30%-80% with the average being 50-60%. Still a lot of room for disaster for guitars.
I don't therefore build to the average as that would be 55% which would lead in the low season to cracks for sure. I tend to follow the industry and stick to building in the 42-47% range and in the low season this is acceptable and unless I expose my guitars to more extreme low humidity would I worry about crack potential.
I also do not keep my guitars out of their cases. I feel that this also helps to maintain more consistent RH for the guitar and if I had a longer season (mine only lasts 30-45 days at most) in the low RH zones, I'd invest and use some humidity control devise in the way of a soundhole devise or one that fits in the case.
PostPosted: Mon Feb 09, 2009 11:39 pm
edit: misread the question.
Mark Burton
Hook 'em Horns
PostPosted: Mon Feb 09, 2009 11:43 pm
Most of my output lives in the midwest so I've been building a tad dry for the reasons mentioned. Around 40%. Probably a good idea to have a neck set that leaves plenty of saddle showing in case it winds up somewhere damp.
TJK
PostPosted: Tue Feb 10, 2009 1:56 am
PostPosted: Tue Feb 10, 2009 2:38 am
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I live in the Australian Wet Tropics, and humidity goes from 40% on the most ideal winter day, to off the chart during the monsoons, like we are having now. I do my best to build between 40-45 % RH, simply because if one of my instruments goes for a road trip into the tablelands, only 1 hour from where I live, it can have swings of RH down to the low 20% during a hot dry spell, depending on the way the wind is blowing.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Tue Feb 10, 2009 9:27 am
Wow, great replies. Tony thanks for the excellent link. Anyone else have anything to add?
Jeremy Douglas
PostPosted: Tue Feb 10, 2009 9:47 am
I was just over at Dave Collins shop and this came up. He said that if he were to get back in to building, he'd control humidity to adjust the dome. i.e. he used to bake the tops at like 170 degrees for a couple hours to get them bone dry. Then you brace them in a deck at some larger radius - he seemed to think it was 65' and then let the atmospheric humidity bring it in to about 25' at 45%.
This would provide some serious protection against drying out because worst case, you'd be at 65' dome. Apparently steinway does something like this with their piano soundboards and there is a difference in timbre as well.
p.s. Hopefully this is not one of Dave's secrets...it didn't seem like it.
PostPosted: Tue Feb 10, 2009 10:10 am
"Hopefully this is not one of Dave's secrets...it didn't seem like it."
No, you're ok. He actually talked about this in a similar thread I started before. Here's the link viewtopic.php?f=10101&t=19874
Jeremy Douglas
PostPosted: Tue Feb 10, 2009 1:05 pm
I like to build at 40%- 45%... Just seems safer to build at a slightly lower humidity to protect from cracks. At the same time the guitar owner has got to be on the same page, or all goes for naught.
Chuck
